Display PoE Port Status
Perform the following procedure to display the PoE status for each port. You can use this information to view the status, classification, watts, and priority for each PoE port.
  1. Enter Privileged EXEC mode:
    enable
  2. View the port status:
    show poe-port-status
Switch:1#show poe-port-status
                                POE Port Status
      ADMIN   CURRENT                        LIMIT            FAST PERPETUAL
PORT  STATUS  STATUS          CLASSIFICATION (Watts) PRIORITY POE        POE
Port mgmt does not support DTE power
1/1   Enable  DeliveringPower Class0         98      Low      Disable    Disable
1/2   Enable  DeliveringPower Class0         98      Low      Disable    Disable
1/3   Enable  DeliveringPower Class0         98      High     Disable    Disable
1/4   Enable  Searching       Class0         98      Low      Disable    Disable
1/5   Enable  Searching       Class0         98      Low      Disable    Disable
1/6   Enable  Searching       Class0         98      Low      Disable    Disable
1/7   Enable  Searching       Class0         98      Low      Disable    Disable
1/8   Enable  Searching       Class0         98      Low      Disable    Disable
1/9   Enable  Searching       Class0         98      Low      Disable    Disable
1/10  Enable  Searching       Class0         98      Low      Disable    Disable
The PoE status of all ports is displayed. The preceding output is a sample of the full output.
